Cut industrial felt with TS55?
Lfab
Hi, has anyone ever tried cutting thick (1/4", 1/2") wool and/or synthetic blend felt with a TS55 or similar?
Nope - thinner I would expect to wrap around the axel like a bad job with snow chains.
If you were doing a lot of the same, then the sweat houses use some laser job I think for fabric ???
Interested to know how it works?
Bringing a sample of the stuff to where a saw it at could be worthwhile.
Where are you at?
I suspect that having a solid material on top and possible bottom like the cheapest thinnest material or perhaps even cardboard would improve your chances of success.
I have tried to cut thinner material like that, and it didn't go well. The blade just ripped it apart.
There are knife edge circular blades for power cutting paper and such, but they are usually small diameter. None for TS55.
I forgot... I have some of the Festool jigsaw blades for foam rubber.
These are like bread knives with a wave shaped edge.
Dunno is there is a circular version, or if the jig version is worth a try.
They fit in any jigsaw,
I think your best bet is to sandwich the felt between two layers of thin wood/foam, make the cut and then analyze the results.
If this were my project...I'd very tightly sandwich the felt between 2 layers of 1/2" foam  board and then use the wave blade in a jig saw that [member=40772]Holmz[/member]  mentioned and monitor the results.
My fear is that a circ saw blade will turn the felt into an expensive hamster bed...
I would probably start with a nice set of Fiskar or other high end scissors... ;)
Good one sparkritiAn.
The Olfa pizza cutters for fabric are also very good. They are about $30-50$ from memory... They last along time, and work on carbon fibre and fibreglass, on Kevlar the shears/scissors are better.
If you need to cut a large number of linear feet of felt, you may want to look into purchasing a "rotary fabric shear".
The rotary fabric shears use a sharp, semi-round blade, bevelled on one side only, and flat on the back, with flats milled onto the edges making the blade hexagonal or octagonal or whatever. The flat back of the blade runs against a lower anvil that rodes under the material being cut, and some models have a spring loaded honing wheel that runs against the bevelled edge as the blade turns to keep the blade sharp.
The rotary shears are usually manufactured for industrial use for cutting multiple layers of fabric, as well as sheet rubber, carpeting, and other typesu of flexible flooring, and sheet goods.
Bosch used to manufactures a cordless version, model GUS 10.8, that uses their 10.8 volt lithium batteries. The bosch can only cut up to 11mm though. The Bosch isn't officially sold in the USA, but you can usually find them for sale from overseas sellers on ebay.
Otherwise you can find corded rotary shears from a number of manufacturers that work the same. I think most are probably manufactured somewhere or other in Asia, but they likely work well enough. Prices vary, and you would need to check cutting capacity, but a lot of the shears cost $200 or less, and in some cases less than $100.
This model supposedly cuts up to 22mm.
https://www.amazon.com/gp/aw/d/B01A...sr=8-4&pi=AC_SX236_SY340_QL65&keywords=rotary+carpet+shear&dpPl=1&dpID=41JJ-rD%2BvoL&ref=plSrch
This cordless model supposedly cuts up to 1/2", and appears to be identical to the older Swiss made Bosch model that bosch manufactured for a couple decades or more but later discontinued.
https://www.amazon.com/gp/aw/d/B01M...sr=8-1&pi=AC_SX236_SY340_QL65&keywords=rotary+carpet+shear&dpPl=1&dpID=31mbArHQF1L&ref=plSrch
This place has a number of different models to look thru.
http://www.allbrands.com/categories/134
I've only used an older Bosch cordless version that had a practically dead in the grave battery, but the shear sliced thru rubber flooring like it was butter for as long as the battery lasted.
