Cheese
- Jan 16, 2015
mino said:But to me it is like using that Porsche cabrio to haul your furniture.
Like this?
rst said:Easy to tell his handicap...way too much money to have common sense
Cheese said:rst said:Easy to tell his handicap...way too much money to have common sense
Well if our new task is rating handicaps...this guy just nudged the meter a bit higher.
Hauling timber in a Ferrari FF. You'd imagine that someone that spends $175,000+ on a car could afford a truck. Or if he's really a cheapskate...would be willing to rent a truck from Menards for $19.95 an hour?
squall_line said:Hauling timber in a Ferrari FF is what the kids these days call a "flex". The ultimate "I have enough money that I don't care, this is how I'm going to get my lumber" move.
dellato said:Yes, WD40 here definitely is more like a release agent than a lubricant.
I also have special fluid for assisting with cutting threads in steel. Maybe that would work? On the other hand, having to spray it on the workpiece - and thus on the saw bed - worries me a bit. Getting oil or oily substances there perhaps might make it on the surface of wood cut after the aluminum, making it more difficult to finish with stains, etc.?
Crazyraceguy said:Michael Kellough said:If you chop, stand the stock up against the fence.
If you slide clamp the stock down on the table and maybe put some wood on top, or slide a little slower.
It’s also helpful to put some kind of lubricant the aluminum. WD-40 or even denatured alcohol, especially if you slide slowly.
When I was in a vocational school machine shop(many years ago) they taught us that denatured alcohol was the best thing for aluminum. Of course this was before "Tap Magic" or anything more specialized was put into use. The main point was no oil
What's that other stuff? A9? something like that. It's more of a paste type stuff, supposed to be ok, but I have never tried it myself.
kmickey said:WD-40 is one of the most misused/understood things out there. WD-40 = water displacement, formula #40. It’s a great degreaser/cleaner, and very short term lube - like minutes. Lots of people use it on their bike chains and then wonder why they don’t last. It’s because they forced all the grease (and dirt), but are now running a dry chain. WD does make bike lube, but that’s completely different stuff.
luvmytoolz said:kmickey said:WD-40 is one of the most misused/understood things out there. WD-40 = water displacement, formula #40. It’s a great degreaser/cleaner, and very short term lube - like minutes. Lots of people use it on their bike chains and then wonder why they don’t last. It’s because they forced all the grease (and dirt), but are now running a dry chain. WD does make bike lube, but that’s completely different stuff.
Yes! This drives me up the wall! The ones that really make me raise an eyebrow is when they say they use it on outdoor steel surfaces to protect it!
