So, I assume you finish the corners with a jigsaw after you have done the plunge cuts......Huh???
I ALWAYS do my cut-outs prior to the installation of the tops. I have lost count of how many kitchens I've ripped out that have had the rails and gables cut up where the tops have been cut-out in situ. It is a bodge IMO..!!!!!
What do you do if the cut-out HAS to have radiused corners, for example, solid Surface tops?
Personally, i find 4 holes drilled of a diameter to suit the hob or sink are simple to do.
The Gecko is useful for so many things, especially long cuts on solid surface material where you need 100% accurate joins. I use 2 on island top fabrication when using a 3mtr rail. Perfect butt joints every time.
The island top in my picture on the LHS here was cut in this way!
Tim.
Tim
Yes I jigsaw or multitool the corners, I don't fancy trying to lift a 3-4m top in on my own with a cutout in the middle, I do commercial jobs and very often the plumber will be supplying the sink so it may not be onsite when i'm fitting the kitchen and they want the tops on so the tiler can get his work done, its not perfect but its the way it is and wont be seen.
remember Chippendale never used to plane the boards on the back of his cabinets
I have looked at the geko in the past but never really had an issue with my rails moving to be honest but if you have one then it does give you peace of mind I suppose
