Ok, my garage is gross, never finished the wainscoating.. will be a lot easier to finish now!!
Here are some pics of my steve jones inspired setup...
Needed to be able to put it together and break it down quickly.... probably will take 5-10 minutes to do...
I used two pairs of sawhorses with 2x4's as the base.. will probably make some rolling cabinets..but for now sawhorses are really easy for me to store.. very sturdy.. even stood on the table to screw eye bolts in the ceiling...
[attachthumb=#]
Here you can see basic set-up..
2 doors both 6'8" one is 30" wide one is 24" wide.
clamped together at first..then I attached the incra track fence on the front...it's 1 1/2 tall so i added a 3/4 strip underneath to bring it to the same height as the mdf.. also I don't think I will ever need it taller than that..
and used 3/4"mdf pieces on top.. through bolted and attached with wing nuts.. so they wouldn't move and easily removable.
woodpecker super tracks... were used for clamping.. they are amazing.. and versatile.. they are attached with hex nuts.. and thumbscrews underneath..
I simply loosen them and slide them back out of the way when ripping.... very easy..
[attachthumb=#]
