paulhtremblay
- Jun 4, 2014
Does anyone have any good tips on how to make accurate, repeatable dadoes and rabbets with a Festool router and guide rails, for example, for dadoes for the backs of cabinets or for drawers?
My method now involves sneaking up to the correct width, a rather tedious process. To cut a dado for a 19 mm (3/4'') piece of MDF, I scribe two lines 19 mm wide. On the MFT table, I set up my router on the guide rail and slide the board in place, lining up the bit with the outside scribe mark. I set my fence stop on my fence. I make one pass with the router.
I do the same for each board.
I put the original board back on the table. I have a 6 mm wide mdf I use to move my fence over 6mm. I make a second pass. I now have about .7 mm left to cut. I measure as best I can how close I am to .7 mm, and then use feeler gauges to move the board over a bit less then a I need. I make another pass. I estimate how much more I need to take off and keep moving over the board, about .1 mm at a time, until I can fit a board in the dado. I set my fence stop against the board, and then do the rest of my pieces, using the fence stop.
This method, besides taking a long time, produces a fit just barely adequate.
I've also tried using the adjustments on the router stop guides with varying degrees of success.
I don't have a kermaker and can't get one, because Bridge City Tools is currently not making them. I'm not sure how well one of these would work with Festool. I have seen Paul Marcel's video, but I wonder at the ease of using a drill collar as your reference.
Also, I have seen the many videos on making jigs for exact dadoes:
http://www.thewoodwhisperer.com/videos/exact-width-dado-jig/
But I don't think these jigs would work on the very edge of boards, being so wide and heavy.
Is there a more Festool way of doing what I want? Would the template system help at all? (The template system looks interesting, though I can't quite figure out its exact use.)
