DG/PRO - DRAINER GROOVE PRO JIG
Brand new, box never opened (see pictures)
Can be used with any router to make drainage groves on Countertops, Chopping Blocks, Trays, etc.
Can be used with many of Trend's other jigs, which fit into this jig
Selling because I have another one as well, and do not need two
Frame for routing drainer grooves in solid timber and solid surface worktops.
Made from 15/32-inch hardwearing CNC machined Compact Grade High Pressure Laminate.
X and Y-axis ski and carriage allows forward and back, and side to side movement.
Provides a 0.5 degree fall.
Router carriage has hole to accept a 1 3/16-inch guide bush.
Carriage can be locked to allow parallel groove routing for standard drainer grooves.
Router carriage can also be used for tapered surfacing applications with a 3/4-inch diameter straight cutter.
Outer frame has index holes at 1 15/16-inch centres to restrict length of slots and includes two index pins.
Five inner templates accessories available to give various groove affects such as straight slot, straight fan, curved fan, lightning fan and hot rod.
Router carriage is not used when inner templates are fitted.
Requires suitable plunge router with 1 3/16-inch guide bush and cutters.
Patent App. No. GB1718517.4
A Unibase may be required for certain makes and models of router.
This product includes:
1 x Frame
1 x Router carriage ski assembly
2 x Index pins
1 x 4mm hex key
1 x 5mm hey key
Specifications Metric & imperial conversion
Fall 0.5 degree
Groove length 17 19/32"
X-axis 17 19/32"
Y-axis 1611/32"
Length 23 5/8"
Height 23 5/8"
Width 15/32"
Weight 4kg
Guide bush 1 3/16"
Plunge router 1/2-inch
Cutter Cove R3/8"
1 x Frame
2 x Index pins
1 x 4mm hex key
1 x 5mm hey key
Fall 0.5 degree
X-axis 17 19/32"
Y-axis 1611/32"
Length 23 5/8"
Height 23 5/8"
Width 15/32"
Weight 4kg
Guide bush 1 3/16"
Cutter Cove R3/8"
