DIY panel clamps
ear3
New York, NY
For keeping panels flat under clamping pressure when edge joining multiple boards, I have used my bow clamps before. But these can be a bit fussy to set up, and since I only have one pair each at the 2, 3 and 4 ft. lengths, I was coming up short on these 16" panels I had to make.
So I decided to make my own set.
Started with a 4 ft. piece of square steel tubing sourced from Home Depot, cut it in half, then drilled 4 mating holes on each side with the drill press (done while bars were stacked on top of each other so holes would line up)
Notice I ground a distinguishing mark on each side/face of the pair to ensure correct alignment when clamping.
Then I planed down some scrap pine to about 3/8th, and crazy glued a strip to the inside face of each metal bar (one bar of each pair ultimately ended up with scrap on either side, as I initially glued the scrap incorrectly to outside face)
Then drilled out the through holes on the wood.
The purpose of the wood skin is two fold. It protects the piece being clamped from the metal, and I'm also able to attach with a pin nailer a small block of scrap the same thickness as the panel so the edges don't get dented, as you can see here from the picture of the completed clamps, where the 5/16th threaded rods have been added.
I used a nylon locking nut btw on the bottom of the post to make screwing it down easier.
If I were to do them over, or make another pair, I might instead attach the wood skin with countersunk self tapping screws instead of CA glue, so they can be easily replaced as needed. I also might use something more robust than pine, which has already gotten a little beat up after only one project. I was just concerned about using a harder wood that might crimp the edges of the piece being clamped.
But in the end you actually don't have to apply that much pressure to make them work. Just three taps on the impact driver was enough.
Here they are applied to a board that I had already done
Keeping the panel perfectly flat according to the Starrett straightedge
And as long as you do your cuts of the original tube stock reasonably square, and align the ends when drilling the holes for the threaded rod, they will stand up on edge even when the panel is clamped up (that panel is being supported by the panel clamps themselves, which protrude further from the edge of the stock than the Bessey clamps.
All in all very happy with them, and I plan on making a few more pairs.  Altogether, the components came out to around $25 (4 ft. square tube, 4 threaded rods, package nylon locking nuts, package regular hex nuts), which is still less than the cost of one prefab panel clamp you might get from Damston or Lee Valley:
http://www.rockler.com/damstom-38-in-panel-clamp-blue
http://www.leevalley.com/us/wood/page.aspx?p=31181&cat=1,43838
Nice work!
How stiff is the steel?  I'd be interested in an update if you ever get up to a 4' pair.
Did you put a crown on the wood? Also, did you consider putting the blocks right up against the pane rather than close to the bolts, so that you could get a little extra tension on the bolts?
Thanks [member=61231]HarveyWildes[/member]  Steel is very stiff.  I suppose if I were going to be gluing up thicker panels of heavier wood, I might order some thicker tubing from McMasterCarr.
Good suggestion on placement of scrap, I'll try that.  In practice, though I've found that because the steel is already straight and rigid, you don't have to amp up the pressure the way you might on a caul.  Which is also why I didn't crown the scrap.  As long as the nuts were locked down, the panel clamp did not bend on the mahogany panels I was joining.  Though again, maybe I will find that I do need to add more pressure when gluing up, say, a 2" thick 4 ft. wide panel of white oak.
HarveyWildes said:
Nice work!
Nice job.
Thing to keep in mind though is that the clamps like the damstons exert pressure in four directions.  They eliminate the need for the bar clamps like the besseys you used in the photo, making the cost a little closer.
Bar clamps are more versatile though.
Didn't realize that.  Wouldn't you have to use like 4 of them at least to clamp the panel the entire way?
That would actually not be that difficult to replicate, provided the tube was large enough to accommodate larger threaded posts that also had threaded pass through holes.  I assume those types of posts, like the kind you see on the Lee Valley model are available from someone.  Maybe McMaster Carr?  Does anyone know what they're called so I could search for them?
antss said:
Nice job.
