Bob,
Thanks for the reply!! Using the Rotex for polishing on your wife's car is perfect and effective use for the tool!! I don't want to give the wrong impression, I have used the Rotex on a couple cars at the polishing stage between initial correcting and final machine polishing as well as a revisit of a regular client's car - light polishing before winter waxing. The Rotex, like the Flex, does offer power enough to perform some levels of correction but, I prefer to use the DA/Orbital to remove halogramming or buffer trails leftover from an aggressive session with the rotary, removing severe marring and scratches. While capable of removing some defects from most cars paint finish's, the DA/Orbital units take much longer to achieve the results of the rotary. And, if working on the rock-hard nano-particle ceramiclear coat found on many newer, high-end German and Italian cars, the DA/Orbital really isn't capable of matching the results of a rotary in the hands of a professional. That said, for those who haven't yet mastered the rotary, the Rotex is an excellent choice! The DA/Orbital function is a safe alternative to the potentially disasterous results of a high-speed rotary in the hands of an inexperienced user.
My initial impression of the Rotex was that it is big and clunky. Happily, once laid to the surface of the car, the Rotex performs nicely. The option of the forward handle is not necessary. The ability to comfortably mapiulate the machine around the surface of the car is very easy, right out of the box! 30 seconds into its first use I made mental note of my first comparison to the Flex - ease of control. The Flex has a mind of its own; travelling all over the car's surface. One benefit of DA/Orbital use should be peace of mind - being comfortable that you are capable of polishing without worry of damage to your car which, is a bit tough when, IME, trying to control the torque of the Flex; having to worry about the machine getting away from you and plowing throught the windscreen!!! And, while the Flex does provide awesome power capable of some levels of paintwork correction, it gets hot...fast!!!!! Be prepared to wear gloves if you want to hold on to this thing for any period of time. And, if you dial up to speed 6, you can forget the long day, thermal shutdown is only about 5 minutes away!! Design of the Rotex, IMO, is far superior to the Flex. Thought was put into the user having this machine in hand during extended periods - working until the job is done! Design also plays into the ability of the Rotex to perform. Comfortable hand placement is essential when moving this machine around horizontal and vertical panels of the car's surface. Having to fight with your tool makes for an exhausting job! In fact, I enjoyed this experience so much, I almost thought about polishing my girlfriends car!!
Thanks for reading!!
Drew
Bob Marino said:
Drew,
Welcome. Ditto what John said. Looking forward to reading more. I have been using my RO 125 and sponges on my wife's car and my own with nice results...but if there is a better product, I am all ears.
Bob
