Does Anyone have a plan/drawing for the T-Lock and Sys3 systainers
Wood_Slice
As stated above I want to make one of my systainers for sorting my D125 sandpapers I could use a cardboard and try to get it close but I rather have it perfect [big grin]. So does anyone have a picture file I can print?
This has been brought up before. I know there is at least one thread about it and people have posted what you are looking for or links to where you can find it. I think if you do some searching you will find what you want.
I gave in and decided to just purchase the Systainer with the insert already in it.  I think the insert itself is available as a separate part, but I'm not 100% sure.
Oh the pain.  I'm trying to make the point to Tanos that releasing a few drawings, svg, dxf type assets for the interior inserts would help in building the community.
Systainer.Store said:
Oh the main.  I'm trying to make the point to Tanos that releasing a few drawings, svg, dxf type assets for the interior inserts would help in building the community.
That would be fantastic. Thank You Very Much
That would be golden. Lots of companies offer the full CAD file of their products.
Also looking for accurate plans of Sys3 sustainers. If anyone comes across a CAD file of any of them let me know! As of now I can only find T-Loc versions but no Sys3 CAD files.
ToolGuy42 said:
Also looking for accurate plans of Sys3 Systainers. If anyone comes across a CAD file of any of them let me know! As of now I can only find T-Loc versions but no Sys3 CAD files.
[member=41832]WastedP[/member] recently released an SVG for the lid of the Sys3 L models.  I wonder if he's done anything with the interior of the Mediums...
I did get a couple of systainer 3 M cases at the same time as the L's, but I haven't done any organization in them yet.  If that changes, you'll see it here (or Shaper Hub) first.
First time poster, long time lurker. I've been working on some inserts for the new systainer3 M line, and figured others could benefit from my SVG files. These are based on an M112 (haven't checked it yet against the taller M line systainers, but I do plan on working my through the rest if there are differences, which I'm sure there are since there were with the T-Locs). I Modified [member=41832]WastedP[/member] 's L lid to fit the M width as well (hope you don't mind).
Layer 0 - base layer with molded X shape cut out
Layer 1 - between layer 0 and 24mm up
Layer 2 - from 24mm to top layer
Layer 3 - top layer with cutouts for lid protrusions.
Lid - Lid
*edited: Layer 0 and Layer 1 were tight fits and needed to be slid in at an angle under the lid side hinges, which can be problematic if you're doing thick inserts, so I made alternate versions that have enough clearance around the hinges to drop straight in. Also attached zip file instead of individual links.
Lid - Lid
Thanks for these!
Anyone have an SVG file for the top of sys-3 medium toolbox? Would be nice to have the outer perimeter and holes for the screwdrivers.
