Forrest Anderson
- Jan 23, 2007
I am repairing and altering an office cabinet which is made of veneered chipboard (particleboard in the USA). The hinges have been screwed into the edge of the door, and particleboard being what it is, the screws have worked loose.
Whilst I could use longer screws with a coarser thread, specifically manufactured for man-made boards, it occurred to me that I could drill out the existing screwhole and glue in a 10mm dowel. I could then drill a pilot hole in the end of the dowel to accept the screw for the hinge. The screw would be going into the dowel's end-grain, but it would likely provide a much better mount for the hinge than screwing into the edge of the raw particleboard.
It then occurred to me that a Domino could be used in the same way, as per the diagram below. Here, the right-hand pilot hole is drilled directly into the chipboard, the centre hole is drilled into a dowel which has previously been glued into the board, and the left-hand one has a Domino.
(The board looks like MDF because I couldn't immediately find a coarser particleboard texture)
I don't have a Domino, but it seems to be quite a good use for one. Has anyone used a Domino for this type of application?
Forrest
Forrest
