Kodi Crescent
- Aug 6, 2010
I frequently have problems with Dominos blowing out the side when I assemble work pieces. One way I've tried to solve this was to use the middle cutting width setting. Sometimes that still doesn't work, and the dominos still catch on the mating workpiece and blow out the side of one of the pieces, ruining the piece, or making something that was once stain grade, paint grade.
One way to further reduce this problem would be to round off or angle the corners of the dominos. Dominos shaped like this would be more likely to guide themselves into the holes upon assembly, reducing blowout. Domino blowout is my chief complaint about the Domino.
I anticipate there will be those that like the rectangular dominos. Festool could offer two parts, a rectangular domino in each size, and a rounded corner domino in each size.
When you are about to plunge, it can be difficult to see the layout line through the alignment gauge. A simple LED lamp that shines in the alignment gauge area would be really helpful.
