Brice Burrell said:SRSemenza said:Hi,
I use both 5mm and 6mm on plywood carcasses depending the situation. You can use the 6mm and keep it from going through by doing a 12mm deep mortise in the face and a 28mm in the edge.
Yes, if you remember to change the settings.....
No doubt. In fact having almost made this mistake I now make a point of cutting the shallow ones first. That way if I forget I am still in the clear.
