I love this forum, fast paced and good members. [thumbs up]
Thanks to all that replied and thanks for all the suggestions that I had yet to consider. I have been thinking a lot about this and have no doubt I can find the right sanders for what I am thinking of but I am equally concerned about the extractor. Sheetrock dust fouls everything up and I am going to go for it and will see the over all long term effects of drywall dust.
Alex said:
Before anyone mentions that Festool's drywall/ plaster specialist the Planex has a round pad, remember that it has a specially designed head with brushes to contain the dust, which the other round sanders don't have.
[attachthumb=1]
Alex, as Scott posted above I had a chance to try the Planex and have been wondering if the round specialty head could be developed for an added attachment to other sanders.
Erik63 said:
Depending on how much sanding you are looking to do, a 150 would be better in my opinion. I have used my RO150, but I think the ETS 150/3 or150/5 would be best.
Erik, I do complete houses a couple times a year and a lot of repairs through out the year so I was mostly thinking of repairs at the moment and if it was working out well then probably advancing to seeing how much the systems can take as long as production was met or exceeded.
PeterK said:
Just my opinion here--- Most any cheap sander works fine for drywall and can be disposable. I think drywall dust is really abrasive and as I use my Festool sanders for wood primarily, I just hate to abuse them with drywall dust. I use an old PorterCable PC333 6" sander that has dust collection. I hook it to my Midi vac and it works great for that. Now the issue really is just how much of this you are going to do and how big an area are you sanding? If this is a full time business, your needs are far different than someone remodeling or just patching. For full time professional use, I would think you need a sander with a large pad area to get smooth transitions and for speed. For me, primarily patching, sanding prior to painting, small remodeling in my own house, a $75 sander works great. I have used my RO150 for this but it was way too heavy. My 150/3 is my finish sander so I save it from this usage. So far, I have used that old PC333 for about 5 years for occasional drywall usage and my son used it for redoing half his house and it still runs great. The vacuum is the key of course to keep as much dust as possible out of the motor. I find a 6" sander to really be perfect sized to cover area and to keep transitions smooth.
I am looking at this from a different angle, I too know how drywall dust takes its toll on tools and am willing to see how Festool handles that.
I am considering the Midi and the CT-26 not yet decided on that. I like how the Midi will fit in the van but not sure I should just go with the 26. I know the Extractor is the key to this being successful so I want to make the right choice.
I am mostly a painter and see a lot of repairs throughout the year along with a couple complete homes for drywall so yes it is my job. Thanks for all your suggestions Peter. [smile]
honeydokreg said:
i use the 125 all the time for patching etc and it works great and have been using it for several years with no problems the customers love it when you tell them you can patch and sand with a dustless sander it usually gets me the job.
especially ceiling repairs it does not fall in your face... i use the midi van the small middle one and it works great no problems at all.
Thanks Kreg., just what I am thinking.
Paint and Hammer said:
Hey Sean....to be honest I too have been concerned about using a power sander for drywall. That dust is nasty! Just been using Mirka hand sander.
May try some of the suggestions here.
I know what you mean Paul. I am thinking of how Festool will benefit my business and see some positive signs in this thread.
fatroman said:
Wound up getting the DTS400 for something else, but because of the posts here and some encouragement from another member,
That is what I am looking for like was already mentioned a good mostly dustless system will make us more efficient and will aid in selling jobs.
Tom Bellemare said:
For optimum performance, the new fleece bags are recommended for your CT.
Thanks Tom.
Ken Nagrod said:
I've never needed to go above 150 grit. Anymore than that and it's like polishing the compound, which might create a paint adhesion issue. Might. All you need is to remove visible sand scratches, not buff it to a shine.
Thanks Ken.
SteveC said:
I use my rts400 w/ 220 and CT26 for drywall. Unlike wood I doubt you can "polish" the grain closed and cause adhesion issues.
The new Midi's now have same motor as CT26 so it's just matter of portability and capacity.
Yeah I know that is what has me going back and forth on the subject.
GreenGA said:
I must concur with Ken Nagrod's post, a few posts up. [thumbs up]
Since we do not have the Planex, we use the two 400's for all our drywall sanding. Once, only once, did we try using a ROS from another manufacturer. For weeks afterwards we were cleaning up the dust. [sad]
The only advice I can offer is carefully control the suction from your CT. If you get it ... just... right, the sander will float on the walls as it's doing its job. Too much, and the sander will be plastered, no pun intended..., to the wall instead.
Thanks Green.
Scott B. said:
Sean
You ought to try one of these out:
[attachimg=#]
I would love to try it out in a work environment Scott, right now not available and not sure what the cost would be when it is. I liked how it performed but at the moment I am envisioning repair work and that would be over kill for many repairs. I keep mentioning it but I would like to see that head option available for other hand held sanders.
Scott B. said:
Peter Halle said:
For those who do not know that is a Planex being used to sand drywall on a temporary wall set up in the Festool USA conference room.
Hope to see those in North America in the future!
And the person in the picture is the original poster in this thread. I believe Sean may have put the Lebanon facility under surveillance. [big grin]
Yep that good looking guy is me. drank the green kool-aid and now the Festool guys are getting tired of my questions lol.
Alex said:
I also mostly use 120 grit paper. 180 works too but is slower. You can't close the pores as Ken suggested. There will be no adhesion problems with any grit.
For drywall my go to paper is Granat, I have found that it clogs a whole lot less than Brilliant. On wood I see little difference between the two papers, but with drywall/plaster it's evident.
I like the Granat too from my limited experience.
That took a minute to respond, if I missed any I meant to comment to I will come back to it. Thanks again for all the on topic advice.
