blaszcsj
- Feb 21, 2015
I have the OEM size cutter head. I do not know actual power draw, but you do have to reduce cut depth significantly (quarter turn only) or the motor goes into thermal overload after continuous use. However, surface finish and noise reduction are massively improved over the steel choppers. It is worth it if you are in a small shop environment and need something cost effective that produces great results, but I am selling mine off to get an A3-31. I just want something with more power.
