Carroll,
Not meaning to personally attack your response, if you took it that way I am sorry.
I would agree with all you are saying and the commercial shop will likely use an expensive dedicated edge sander. I read the post as looking for suggestions, not just sanding suggestions. Therefore my answer and suggestion. I do think it is valid if one is doing a few pieces. If it is the right choice for a non hobbiest is another question for sure. Hopefully if one is doing 50 doors a week or a day they will be making different choices.
In the past I have had the similar debate regarding raising panels with Mike Dunbar. He felt his panel raising plane was very time effective because it left a surface ready to finish. I argued that I was doing 120 panels in each batch and the only efficient way was to use a shaper and high production sanders. Mike would certainly spend nearly as much time sharpening his plane to do 120 panels as I would with machines to finish them all. We can both be right or wrong but for different reasons.
The beauty of woodworking is that there are so many ways to get the job done and get to the desired result. Certainly most of the finest furnature of the past was made primarily with hand tools only. But if power tools were available the old craftsmen may have used them. I think the Shakers likely would have.
Best,
Todd
[ quote author=ccarrolladams link=topic=20790.msg212143#msg212143 date=1340588395]
Notorious T.O.D. said:
I'll go a bit old school and say LN block plane and Festool hard sanding block. Not a bad choice uless you have a large amount of doors and drawer fronts to do. Plus it will build your skills more with the block plane. Probably a bit less expnsive too!
Best,
Todd
Whatever floats your boat. Probably people who are way into woodworking as a hobby should learn to use various hand planes effectively.
My answer was based on the question about sanding the edges, not running them on a jointer or using hand planes.
My experience is that even the most up-scale clients for custom cabinets do not pay extra because hand planes were used where sanders are more efficient. My own satisfied clients are concerned about the fit of joints and the matching of grain. They do not ask how I accomplish the end results. Personally I learned to use hand planes in the late 1930s, then discovered after WWII when affordable hand power tools reached the market that clients would not pay extra for the longer time it took to do the tasks with hand tools.
Perhaps your experiences and mileage vary from mine.
[/quote]
