Lou in DE
- Apr 1, 2015
I am trying to change pads (to a hard pad) but can't seem to unscrew the original pad. I have seen some videos so I'm pretty sure that I am turning the correct direction to loosen (counterclockwise) but it is not coming loose which is made more difficult because you can't lock the pad so I assume you must try to hold the pad with one hand and turn (or try to) the hex wrench with the other.
Does anyone have a suggestion, technique or trick that I might try?
Lou
Lou
