HarveyWildes
- May 3, 2016
I was sanding some Baltic Birch plywood yesterday with my ETS EC 150/3 EQ. It's not the first time I've used it, but it's the first time I paid any attention to the variable speed feature. I was sanding the following progression: 80 -> 120 -> 180 -> 280. All sandpaper was Granat - though I also have a few pieces of Rubin 2.
At any rate, I thought that, hey, if sanding with a spiffy more-or-less new 6" sander with excellent dust control is fast on speed #5, then increasing the speed to #6 would be even faster. (Where is 11 when you want it?) Then, for about an inch of one edge, I sanded very slightly more of the top layer of veneer than I might have liked if it had not been a piece of shop furniture. There was a little 1/16" expanse of glue showing. At that point I thought I might do well to read the manual.
The manual recommends the following:
5-6: Sanding of wood and veneered surface prior to painting.
4-5: Sanding wood with non-woven pad.
4-5: Edge breaking on wooden parts.
3-4: Sanding solid wood and veneered edges.
3-4: Light sanding of natural wood windows using non-woven pad.
3-4: Smoothing wooden surfaces using non-woven pad before staining.
1-2: Sanding stained edges.
Questions.
1. What is the difference between a woven and non-woven pad? I can't find the terms elsewhere in the manual.
2. Why does the manual have special instructions for natural wood windows? Is it talking about painted or bare wood natural wood windows?
3. I'm assuming for general purpose woodworking that the manual is recommending 3-4? Is the woven/non-woven pad thing important for bare wood?
4. It seems to me that the real issue is just how aggressive the sander is. So I might want to use speeds in the 3-4 range at low grits to keep from damaging the surface, but it seems like I ought to be able to increase the speeds at higher grits. Thoughts?
5. How about dry sanding polyurethane finishes (say at 400-800 grit) between coats? Is that where the sanding at 1-2 comes in?
Your thoughts on how to effectively use the VS feature for woodworking would be much appreciated
BTW, I tested the Festool sander head-to-head against my DeWalt 5" yesterday. Festool hands down on noise, vibration, speed, dust extraction, weight, etc. I couldn't find any measure where the DeWalt had a leg up. Despite that fact that it has been a faithful, sturdy workhorse, the poor DeWalt is going to be spending a lot of time on the shelf.
Questions.
