countrysideworkshop
- Jan 24, 2014
Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
countrysideworkshop said:Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
will the older non tapered hose work on the new sanders?SRSemenza said:countrysideworkshop said:Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
The hose sleeve is not included with the EC sanders. It is currently only available with the hose and cord. The wrap / sleeve is also sized for the newer tapered hose. I got a hands on with recently. It is quite nice. Seems to have good flexibility too.
countrysideworkshop said:will the older non tapered hose work on the new sanders?SRSemenza said:countrysideworkshop said:Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
so what actually is the new "taper" hose?Brice Burrell said:countrysideworkshop said:will the older non tapered hose work on the new sanders?SRSemenza said:countrysideworkshop said:Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
Yes.
[member=28105]countrysideworkshop[/member]countrysideworkshop said:so what actually is the new "taper" hose?Brice Burrell said:countrysideworkshop said:will the older non tapered hose work on the new sanders?SRSemenza said:countrysideworkshop said:Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
Yes.
i have the original 27mm hose that I it with my midi last year and my 150/5. But I am selling my 150/5 for the new brushless and don't want to spend another $275 on a hose. So I want to know if that older hose will still work with the new sander and if so what is the real difference with the new "tapered" hose besides it is wrapped.grbmds said:[member=28105]countrysideworkshop[/member]countrysideworkshop said:so what actually is the new "taper" hose?Brice Burrell said:countrysideworkshop said:will the older non tapered hose work on the new sanders?SRSemenza said:countrysideworkshop said:Does anyone know if the new sander comes with the new power cord that has the wrap to wrap around the dust extractor hose? Can't seem to find it anywhere.
Yes.
I believe they are talking about the new 27mm hose which comes wrapped with the cord in a sleeve. I have that hose and it works well where you would use a 27mm hose. It connects to a Festool vac or, if you own a boom arm, it will also connect for use with that. I have found that it is very easy to use with sanders; flexible and you don't have to worry about the cord (even though, on the boom arm, that is already dealt with to some degree). I have also used it with the Domino and it works well. It seems more flexible than a regular 27mm hose, but I don't know that for sure.
countrysideworkshop said:i have the original 27mm hose that I it with my midi last year and my 150/5. But I am selling my 150/5 for the new brushless and don't want to spend another $275 on a hose. So I want to know if that older hose will still work with the new sander and if so what is the real difference with the new "tapered" hose besides it is wrapped.
arent the original hoses the same way? If not then how can you connect a 27 or 35 hose to the dust extractor sideAlex said:countrysideworkshop said:i have the original 27mm hose that I it with my midi last year and my 150/5. But I am selling my 150/5 for the new brushless and don't want to spend another $275 on a hose. So I want to know if that older hose will still work with the new sander and if so what is the real difference with the new "tapered" hose besides it is wrapped.
Your old hose will work with the new sander. The connector is the same diameter.
They call the new hose tapered, because it is 32 mm thick on the vac side, and 27 mm on the other.
countrysideworkshop said:arent the original hoses the same way? If not then how can you connect a 27 or 35 hose to the dust extractor side
neeleman said:The GQ sleeves are sold separately in length 3,5m (500588) and 10m (500589).
Though not cheap as aspected (€83-167 incl. VAT). Which is €23-16/m.
Or what I use is TechFlex Flexopet woven PET covers.
And is a lot cheaper (€2/m) and available in many colours like a Festool colour look alike (neon green).
Cheese said:[member=28105]countrysideworkshop[/member]
When using the Festool zippered hose, the cord and the cover are fairly loose and the ID of the hose is only 22 mm. This hose is a LOT easier to use in tight places. I think it makes an ideal hose for sanding.
[attachthumb=1]
[attachthumb=2]
