If a domino is glued in tight into a joint, what does it matter if it is exterior grade or not? I can see it making a difference if it was to be used as a through tenon but if applied conventionally where it would never be exposed directly to the elements. Is this an issue? I'm interested as I am planning on building some new patio furniture.
Good Day All, we just got notification that there are several new Domino related items that will be available Sept. 1. The "Sipo" domino for exterior applications will be available in all sizes. There will be smaller pack sizes of ALL domino sizes. One other nifty little item is the "Domino Handrail Fence" to be used with hand rails. The Handrail Fence is a "V" shaped attachment to go over round rails and such items. It is a "Tool-less attachment to the Domino base plate. Easily adjustable for both straight and mitered joints. Accommodates round pieces 35-60 mm (1 3/8 - 2-23/64) in diameter."
