lasttoleave
- Feb 8, 2015
rst said:I use Precsion dogs and they fit snugly, with no slop.
Thanks for informing me of that, it's made me happier to persevere down this route further knowing other people have got achieved using the same tools.
Can I ask what model router you are using to get these results?
Bohdan said:Set the router on its slowest speed and plunge as fast as you can in one go. See if that makes a different sized hole and eliminates the burning.
I have tried plunging relatively fast, but there seems to be a lot of resistance and burning almost immediately which makes me ease up slightly by instinct.
I will try some more tests using each router and maybe some time material to begin with (12mm MDF)
rst said:When I make my holes in MDF, I make my plunges one continuous plunge, adjusting the speed depending on bit size. Even when metal machining, with the rigidness associated with that type work there is ridging, probably not as pronounced, but none the less present. In metal working precise holes are made oversize and then reamed to final size. Try slowing the speed, adjusting plunge rate and making a continuous plunge.
Thank you, I will try and incorporate these techniques. Do you have a lot of burning with your setup or are the holes pretty much clean? Would you mind describing the pressure you have to apply when boring your MFT holes?
I think I'll have to push pretty hard to bore the hole in one continuous plunge, but its worth trying. Does everyone use their routers on the slowest speed for this task?
Thanks.
