Festool 487925 Router Bit Systainer Foam pad
nickao
Can the Festool 487925 Router Bit Systainer Foam pad be purchased separately?
I only want the insert.
One thing about these inserts I don't like is  the way the holes are spaced. They only hold like 40 bits. I had to drill my own holes and almost doubled the amount of bits it holds(tons of straight and spiral bits).
The very best foam I have ever found , the stuff I used to customized my drawers in my shop, is at the link below. It's better than the Festool pad, but I want the perfect fit for the systainers I have laying around:
http://www.ptreeusa.com/routerAcc.htm#1044
# 1044 Foam Router Bit Tray and at only 2-1/4" square x 1-1/2" thick they can hold 100 bits, 50 ea 1/4" and 1/2". Accepts 8mm shanks as well.
Thanks for that  :)
Yeah I have two already(sys 1 D8/D12), but I have quite a few systainers I just never put my tools in and I have way to many router bits sitting in a cardboard box. My wife asked if all these router bits should be sitting on top of each other like that, so I better get to organizing them.
nickao said:
I can't find them on the search for Bob's site.
Bob do you have them?
  Nick,
If there is a number attached - I can get them. This looks to be a "parts" item, not from the catalog, so I would have Festool drop ship to you.
Bob
