The best way to start this topic would be to introduce myself. I work in Lincoln NE for Timmy C, that kat you always see online here. Before working with Timmy and jumping into the Festool world I was strictly a wood floor installer and refinisher, along with building a house or two here and there. I Never used a Festool in my life up until 2 years ago.
Now I look back to those days of old and try to figure out how I ever got by without Festool. When it comes to sanding a wood floor, the biggest concern for me is time. The biggest concern for the customer is dust and flawless work. Festool has made my life so much easier. The other day I finished some stairs that were 100 + years old. Instead of pulling out the edger i decided to test out the Rotex and the Deltex. The stairs were flawless. The coarse mode in the rotex and a 24 grit paper was enough to rip off the lacquer. Then instead of handscraping corners I used the Deltex. Then I polished the stairs with the rotex once again. I hate hand scraping corners and after using the deltex i found the time spent is equal. From now on Deltex is the way to go.
Another floor I did was a cut in Border to an existing floor. Here the TS 55 or 75 work just as well with an 8 ft rail. Plunge cut your line, run the 1400 router down one side and make a groove. Throw in your boards and run.
The Festool line is a must have for folks like me. My time on the job is cut in half and talk about dust free. I use my CT 33 on every job, i even hook my edger up to it when i can. ((I'm still working on the perfect adapter). I 'm taking hints on that!) I use it for my buffer in between coats. The biggest thing though is the fact that my customers are amazed that i can plunge cut, sand and buff inside the house with no trace of dust anywhere. Customers are also amazed by how organized you look when you walk into there house. Throw your systainers on a mobile base roll it into the house and the customers are blown away!
So basically I'm trying to rustle up flooring ideas with Festool, experiences, drawbacks, advantages, ideas you have. All i have found is advantages so far!
