festnoob
- Jun 13, 2010
Shane Holland said:Also, if you think the base is too narrow, there are screws that hold the plastic runners on the bottom of the base. You could remove the plastic runner(s) and add a piece of thin wood, Plexi, or something else to make the base wider using the existing screws, or longer screws if necessary. So, you could make the base as wide as you wanted.
Wouldn't that be considered modifying a tool? Big no-no on the FOG [poke] Or is it ok because it's an accessory? [scratch chin] This thread is now locked! [big grin]
Also, I thought about your responses but I cannot get my head around the angle base. When I build cabinets I leave a 1/2 on the ends for scribing an inward 15 degree scribe. Most of the time I take off a 1/4-3/8 depending on the wall, sometimes less. It does not seem possible in my mind. It seems that if the Carvex is going left to right or right to left with the base in the obtuse position, then it would be hanging off the stock or resting by a hair on the stock being removed.
And if the base were in the acute or, better yet, reflex position then the part of the base that overhangs the edge that I'm cutting would make contact with the piece if the scribe line is further in from the immediate edge.
(And no dust collection???) [jawdrop]
Shane Holland said:elimelech12 said:Thanks...would the 30 days apply to the accessory kit also?
Ah, yes, good point. No, our 30-day return guarantee only applies to the tool. Sorry.
However, some dealers may offer their own 30-day return policy on products probably with the condition that its returned in like new condition.
That's a $200 risk. [crying]
