DeformedTree
- May 19, 2018
yeah, sometimes old school holeshooter/hammer drill is the answer, and if you got a lot of holes, the cord is just fine to deal with, verses running out of battery every 2 and a 1/2 holes.
You do want to look at the DRC/PDC and more so the newer TDC/TPC line with their 4-speed gearboxes and 3800/3600 top speed.Packard said:I love my cordless drill, but it spins at 1,375 rpm (no load) and probably 1,000 to 1,100 under load drilling 8mm holes.
My old corded drill spins at 3,500 rpm and does not appear to slow down at all drilling 8mm holes.
I use my corded drill for dowel holes and for pocket holes. Not only does it go faster (much faster if you are drilling for a lot of dowels), the holes are cleaner. Invariably I have access to power when I use those tools and they tend to be used at a specific workstation.
So don't throw out those 110 volt power tools. They do some jobs better than the battery-powered tools.
Packard said:My old corded drill spins at 3,500 rpm and does not appear to slow down at all drilling 8mm holes.
Nothing to do with the drill being corded. Everything to do with the drill not having a brake.Coen said:Nor when you let go of the trigger.
That annoys me the most about corded drills. Drill some 4mm holes in wood and spent longer waiting for the machine stopping to spin the drillbit than actually drilling..
I think a big part of the cordless market is hobby users where the versatility rules and "the battery platform cost" is not high as they can get by with one battery set for a lot of tools, not using them at the same time normally.grbmds said:I'd say that, if you are using the tools in a workshop and do not need them to be mobile, there are limited usefulness for cordless tools. Tools like drill/drivers and maybe jigsaws can be very useful in the shop but, for the most part, I find that I don't need cordless in the shop. Since I would hook up my sander to my CT in the shop anyway, I don't think a cordless tool would be a good use of my money. If I were a remodeler, carpenter, builder, etc., I think the cordless versions of the tools would be very useful in certain situations; being more mobile around the worksite. I only own a cordless drill/driver and impact driver since that is the only tool that was economical and useful for me in my shop.
mino said:Not so simple for a professional user with deadlines so there the trade-off can go with the (lighter) corded tools as the battery change/charge/size is more of a hassle than the cord at often a fixed workstation is.
Not so simple in the sense you PAY for going cordless as a Pro - by needing the pile of charges and batteries and caring for them as you mention.Alex said:mino said:Not so simple for a professional user with deadlines so there the trade-off can go with the (lighter) corded tools as the battery change/charge/size is more of a hassle than the cord at often a fixed workstation is.
Dunno where you get your info, but whenever I work with professionals they have a whole line up of chargers running all day to keep their cordless tools working.
mino said:Not so simple in the sense you PAY for going cordless as a Pro - by needing the pile of charges and batteries and caring for them as you mention.Alex said:mino said:Not so simple for a professional user with deadlines so there the trade-off can go with the (lighter) corded tools as the battery change/charge/size is more of a hassle than the cord at often a fixed workstation is.
This hassle with chargers means there are real advantages to corded tools in a fixed shop setting for professional use so is not as slam-dunk decision is a for a hobby user.
A hobbyist can get by with a single charger/batteries set for tens of tools and not be limited by it. So his economical calculus is different and corded tools have much less appeal even for shop use in the hobby world.
As Festool sells to both worlds, a cordless lineup is a must even if only (high end) hobbyists bought them. That is why we see some tools are no longer offered in corded versions even like the (Qua)drills or now the HK55 going away. They simply do not sell.
Nope.Alex said:It is simple: unless a tool requires lots of power, professionals go for cordless.
Michael Kellough said:The Dewalt has a belt loop but I’m not putting that spinning bit anywhere near my belt.
Michael Kellough said:Packard said:I love my cordless drill, but it spins at 1,375 rpm (no load) and probably 1,000 to 1,100 under load drilling 8mm holes.
I keep a Dewalt corded drill with my Kreg pocket hole kit. It spins at 2500 rpm which is a good match for the bit and at 8 amps it has enough power to keep up the speed, in softwood at least. But, unless I time trigger release bit extraction just right it’s a drag having to wait for the motor to come to a stop before I can put down the drill and reposition the work.
I keep using it because it starts up the vac but I’m about ready to move on to a big cordless drill that can stand upright on it’s battery pack. The Dewalt has a belt loop but I’m not putting that spinning bit anywhere near my belt. Maybe I can make a wire loop rig that can be clamped to the bench...
