MrToolJunkie
- Jul 6, 2009
FWIW - Mafell rails are also ground square and straight on the edge opposite the anti-splinter strip - useful if guiding a jigsaw against the rail.
ScotF said:FWIW - Mafell rails are also ground square and straight on the edge opposite the anti-splinter strip - useful if guiding a jigsaw against the rail.
Could be ground and then anodized? Would that make sense?Cheese said:That'd certainly be a nice touch if that is true...just looked at both of my rails and I could not detect any grinding marks of flycutter/endmill marks on the edge. The surface finish appears to be the same as the rest of the rail. [sad]ScotF said:FWIW - Mafell rails are also ground square and straight on the edge opposite the anti-splinter strip - useful if guiding a jigsaw against the rail.
Svar said:Could be ground and then anodized? Would that make sense?
Regardless, a good quality extrusion is straight enough as it is for any woodworking task.
Cheese said:The only thing lacking in the Mafell rail is the lack of a TSO Guide Rail Square...however, I'm sure Hans [member=59331]TSO Products[/member] is working on it as we speak. [big grin] [poke] [big grin]
DynaGlide said:As a recent purchaser to the Bosch/Mafell rail (I bought a short length Bosch rail) for my newly acquired jigsaw. .I won't be moving my tools over. I like the features of the Festool rails too much. If the selling point is that the Mafell/Bosch rails link up easier, that's solved with aftermarket accessories for the Festool rails and is a moot point. I do like the Mafell/Bosch rails lean low profile feel but that's about it.
StanB said:Has anyone tried the metabo rails?
There is still virtually none and it's not going to change. Simply because there is no place to attach the accessories.yetihunter said:There were virtually no aftermarket accessories for the Mafell rails for quite some time...
Svar said:There is still virtually none and it's not going to change. Simply because there is no place to attach the accessories.yetihunter said:There were virtually no aftermarket accessories for the Mafell rails for quite some time...
ScotF said:The Festool rails stick to the surface better and I do like the green glide strips vs the metal on metal with the Mafell. I also like the anti-splinter insert for the offcut on the Festool and think it yields slightly better cuts vs the Mafell on certain plys - but it is negligible.
Contrasting color sure helps, but how hacked up they are is simply a function of amount of use.Cheese said:However my splinter strips on my Festool rails have always been rather hacked up and look terrible. Consequently it's always an issue when trying to align them with pencil lines. The splinter strips on Mafell rails are always smooth and are vey easy to align on the pencil line.
Svar said:Contrasting color sure helps, but how hacked up they are is simply a function of amount of use.Cheese said:However my splinter strips on my Festool rails have always been rather hacked up and look terrible. Consequently it's always an issue when trying to align them with pencil lines. The splinter strips on Mafell rails are always smooth and are vey easy to align on the pencil line.
