derekcohen
- Jun 22, 2008
Michael, you have an AT65 E as well. What rail length would you use for a 800mm crosscut (I have just measured an internal door in our house)?
Now I am going to throw a bit more into the mix: I do own a rail. It started out as a Makita 1400, and I cut it into 800 and 600. I have the Makita joiners, and can return it to 1400, if needed. Why do I have it? I purchased it about a year ago to use with a router. Having read about the differences between the Makita and the Festool rails, what I fix on is that both work, but the Festool works better. I am comfortable purchasing another rail, but I really only want one for crosscutting. I can switch to the Makita for a longer length, however it will need a little re-tuning, as all know, since there is a smidgeon difference in the guide, which would lead to slop unless adjusted.
I would prefer not to go to another 1400 (I'd rather have a Festool 1400 than a Makita 1400), and anyway, it is now a 800, which is likely to be too short. If the preferred length is 1080, this would also tuck away nicely under the bench. However, that is not the best reason to get it, if it will not do what I intend it to do.
