AlexThePalex
 - Nov 12, 2008
Alex2 said:jmbfestool said:Hey Hey Every one lol!!! Once again the festool drill has failed me again!
The problem with my drill started about a month ago but I need the drill so I didnt bother sending it for repair till last week.
The problem this time isnt that it just stopped working. This time it would fluctuate on me sooo While I was hold the trigger in fully and screwing a 60mm x 4mm screw into softwood or any other screw really mainly above 60mm it would stop go stop go stop go and then carry on going all the way and sometimes it would stop go stop go stop and wont carry on untill id let go of the trgger and pull the trigger in again. I noticed also when it did the fluctuation the drill was not were near powerfull enough so it wouldnt pull the screw into the wood so I would have to realise the trigger and pull again the drive the screw in!!
I dont know if I use a drill incorrectly but I am not having much luck but if the ratio my first drill lasted 1 week then repaired and replaced it lasted a month and this one has lasted a year i think?!?!? The next one will last longer! lol
I have observe that when the battery is near the end of it's charge, my drill will do the same and behave strangely exactly as your description. I always taught that this was normal behavior. What do you think ? Try with another or the same fully charged battery and see if it corrects the problem.
Now with my drill, since day 1, there's a little bit of wandering of the central pin (or any chuck i put on it). Is this normal ?
Thank you
Alex
It works the same for me here, just like Alex describes. It's just the battery running out. The behaviour jmbfestool describes is also the same and doesn't look to me like it's a fault. And the same thing happens with any other drill when the batteries are empty. Only reason it feels a bit differently with the T15 is because of the electronics that will stop the drill automatically when it reaches a certain torque.
