tjbnwi said:
orm8426 said:
tjbnwi said:
Who here would expect their vehicle to be repaired under warranty if you hit something, be it an hour or year old? Neither the jigsaw or vehicles are designed to hit things.
I've had one tool repaired under warranty. All the rest I knew (as most who read my posts know) I damaged out side the bounds of" recommended" use. Looked in the e-Cat order the parts I needed, fixed it myself.
What baffles me most about the original post is how did you jamb the blade into the screw? I choose a blade where the length fully retracted is greater and than the material thickness. Worst that could of happened set up like this is lost a few teeth on the blade.
I think the OP's predicament is more like running over a pot-hole in the road and rather than just getting a chunk taken out of your tyre (sorry "tire" if you will insist on cannibalising our language [wink] [big grin]) your entire suspension and drive shafts snapping.
Again, not the manufactures problem. They did not create, nor hit the pot hole.
Avoid the pot hole, avoid the damage.
Actually it is the manufacturer's problem.
Any product must be fit for purpose by law, and in the case of cars this includes specific tolerances for impact from pot holes, speed bumps, expansion gaps, etc. Car manufacturers build these requirements into their basic design as to avoid future problems that would actually be more costly under warranty.
For Festool to a) not design for this and b) not warranty it is pathetic considering the prices they charge.
