Stan Tillinghast
- Mar 18, 2007
I have my Festool stuff now in Maui where I am working, and I'm starting a new "commission" from the Mrs.:
a hall table, 4 inches long, 36 inches tall. I want the base to have tapered legs (haven't decided on the wood).
The top will be a slab of chocolate heart Albizia with a "live" edge. It's a beautiful piece of wood, but the ends are fairly warped on this 9-foot long by 1 1/8 inch slab.
I have enough to use the middle of the board where warping is the least, but I will still have to flatten one side. I can then take it back to the hardwood dealer where I bought it to run it through a thickness planer if I wish.
I have flattened the surface of a large redwood slab with the HL850E planer with good results. I would use winding sticks and chalk as per my old Fine Woodworking archive. An alternative method I have read about is making a sled on rails for the router Tage Frid style (used for making workbench tops) and slowly routing off the high points of the top.
I have never made tapered legs with the Festool tools, and wonder how you would go about making a jig to use with the circular saw (I have the TS 55 EQ). I want the legs to be thin, perhaps 1.5 inch at the top tapering to 1 inch at the bottom; and I want them to be tapered on all 4 sides.
I am buying a Domino to join the legs to stretchers at the top.
I am happy to have found a source for Hawaiian hardwood so I can finally tackle a long-planned furniture project. Thanks for your help.
