first domino project
dirtydeeds
this was my first domino project, september 2006
all gate and frame joints done with 50x10 dominos, frame head and door head routed to shape using the OF1400
the gate is hinged on the fence side (customers requirement) and so the frame head had to be stuctural
a storm late last year didnt cause any problems
That's very nice DD - shame the customer didn't want a matching new fence too, as the fence just looks really crappy next to your gate!!!
What timber did you use?
they wanted cheap, they got pine PAR stock straight out of merton timber's yard
the door head is a 6 piece lamination the frame head is a 9 piece lamination
What Jonny said. It won't be long before the client wants a new fence. Nice work.
Is the gate panelling tounge and groove? If so did you do it or did you buy it like that? How is the panel receedes into the outside frame of the gate? Thanks if you answer!
      Very nice.  That gate/door looks great with the brick house too!
lancashire 20th foot
the timber is TGV (tongued groved and v jointed) and is avaliable off the shelf
your question seems to suggest you might not be very familar with this form of door construction
apart from it being a halfround head the door is still a standard framed ledged and braced construction.
its made in the following sequence. if you familiar sorry about teaching ducks to quack
the frame and head are 2 inch timber (45mm finished) you rout a 3/10 (10.5mm) rebate into the face of the frame about 1/2inch (13mm) deep. this is for the tgv and the answer to your other specific question
the ledges are 1~1/2 inch timber (32mm finished) these are referenced off the back of the frame, connect frame and ledges (domino joints) you now have the basic door
pin the tgv (about 10mm finished) to the rebate and the ledges. DO NOT cramp up the tgv or it WILL blow the frame apart in winter
then install the braces 1~1/2 inch timber. i reinforced the brace / ledge joints with dominos then flushed them
finally pin the tgv to the braces.
with this technique ive made made 6 doors (square heads) in a day. but its only worth it for non standard doors, standard FLB doors only cost 50 quid each incl VAT
