First extensive use of the Domino and my ETS150/3 (and CT Midi)....
Neal W
Well finally the weather has cooperated along with my schedule and I had the opportunity to use the Domino and the ETS150/3 for the first time. Also I used them (and other wood working tools) in conjunction with my CT MIDI/Dust Deputy setup....Some observations.
Really like the Domino. It is going to be great for doing the things on my project list (MFTC, a few wall cabinets for my garage, etc.).  Like others have said there is a bit of a learning curve, but I'm really starting to get the hang of it.  It really helps to plunge the tool from the pluggit area.  That way your not fighting your other hand causing the Domino to tilt.  I made a plywood shelf with mitered poplar edge banding.  Dominos in the mitered corners and in the edge of the shelf to connect the edge banding.  Fits like a glove.
The sander is really nice, too.  It is a lot better to use than the $30 random orbit sander.  Very nice to work with.
The dust collection properties of the sander work really well, if you follow this key tip!  make sure you actually attach the vacuum hose to the sander.  Otherwise dust spews everywhere! [eek]
Quality sand paper makes a big difference  I used granat sand paper with my ETS 150/3.  IT far exceeds the "el cheapo" stuff I had been using from the true value home center on my el cheapo sander.
The CT Midi just sucks and not as loudly either  I used the CT Midi attached to my Triton router in my router table.  I cut a series of 1/4" dadoes (lots of them).  And while it didn't collect 100% of the chips/dust.  It probably collected 75% of them.  BIG difference, and less time cleaning up.  Almost all of the remaining chips were inside the cabinet and very easy to vacuum when finished.  I also used it with my other brand of track saw and my table saw.  It works "OK" on the table saw (would probably work better if I wasn't using a zero clearance throat plate).  The MIDI and Domino are 100% dust/chip free.
I will have a chance to use my OF1400 more extensively in the next few weeks, and I am looking forward to that as well.  So far so good for me.
Welcome to the world of Domino. It is an amazing tool. I found the Halfinchshy videos very useful. I wish I had bought mine a couple of years sooner.
I am trying to find out if upgrading to a CT with the dust deputy is really an improvement over my shop vac with a dust deputy
You might want to search on this forum relative to static issues involving the Dust Deputy and CTs.
I believe that issue has been resolved.  You won't have any problems as long as you have one of the newer Dust Deputies with the static conductive plastic.
[member=43773]Neal W[/member]: What size hose did you use between the table saw and the Midi?
No pictures of your first project?  [sad]
Welcome to the world of Domino joining and near dust/chip free woodworking.  If you go with the Oneida Dust Deputy look at their site and choose one of their anti-static designs.  I have the CT22 and have been using the Oneida UDD for a few years now and since my unit was not originally static free (even though I never had a problem) they upgraded it with new components free of charge.  I like the option of not always having to stop and change extractor bags.
Sorry.  I have a 2 1/2" hose to go to my table saw.
