stvrowe
- Jan 27, 2007
I wanted to share some of my test results of various frameless cabinet joinery. I used 8mm dowels, #20 biscuits, and 5x30mm Dominoes to create sample joints and load them up to failure. The location and number of connecting members used was based on judgement of what I felt was necessary to obtain adequate load carrying capability. I chose the upper cabinet bottom shelf as being the most limiting since when I construct lower cabinets, I use leveling feet with a flange that provides additional support to the joint.
I was a bit surprised at how much load each of these methods would absorb before failure and concluded that all three methods would adequately support a cabinet full of dishes. In all cases, the plywood was the failure point and not the connecting member. For the dowel and biscuit, the bottom shelf failed while for the Domino, the side of the cabinet was the failure point. Given the bad rap and bashing that biscuits usually get, I was quite surprised at just how strong that joint was.
These are my first ever Youtube videos so your constructive criticism is welcome.
Dowel frameless cabinet joint test
Biscuit frameless cabinet joint test
Domino frameless cabinet joint test
