ilovesunshine
- Jul 22, 2018
neilc said:Nice progress. Your mortises and overall work look good. By the time you've built a few of these and friends commission you for their work, you'll be an expert!
For cutting hinge mortises, I use trim router. Variable speed ones are ideal if you have that option. A Dremel tool with a router base is even smaller and works well too.
I first place the hinge on the door or frame, optionally screw in one screw to hold it and and use a knife to mark the edge on the outside. Remove the hinge and set the router to the hinge leaf depth and then remove the bulk of the material with a 1/4 or 3/8" router bit. You can then use a chisel to clean up the remainder using the flat bottom as a reference for light easy strokes. Consistent, fast, and with a little care they turn out great.
Hi Neil,
Thanks so much for reading and for taking the time to reply. Haha, yes the more you practice the better you get - that's what I'm hoping anyway! Just buying a house with my partner and will have My Own Workshop there - can't wait!! So excited!!!
I too your advice and went and bought a Dremel - had seen them for years but always thought they were for more hobby type stuff or small models - and I guess they are really - I went for the cordless model in my ignorance and couldn't have picked a more gutless machine to chunk out the door hinges - plus am finding a few issues with holding the base totally square to the work as the 'work' is vertical - and the router base when I am cutting near the top or bottom, can slip off into the already cut bit from the other end of the hinge - and then if I hold the router base on the wood that is still the full height - some of this is the next bit of frame which isn't totally flush with the bit I am cutting - so my nice depth on my practice bit turns out to
not be totally what I had hoped - still this is all good experience - I am still glad I went for the cordless one as it's so easy not having cables - I just need at least 1 more battery ideally!!
In the meantime there is plenty to keep me out of trouble (!) - trying to rescue the hinge mortises I cut out of the doors yesterday for one!! Partner suggested good quality 2 part wood filler as some bits are perfect, others are to deep.
Anyway this is all likely elementary stuff for all you master carpenters, haha, I'll post some photos when I have something more impressive to post and more progress!! Hopefully with the doors all hanging nicely with a nice uniform gap around them all by end of tomorrow so I can commence the door cladding - thank you so much for the help and encouragement
