weedsnager
- Feb 2, 2023
Getting shocked from my sander, using it with the Ct 26, both are brand new, anti static hose…
Any help ?
			Any help ?
Cheese said:Is the electrical outlet that you've plugged the CT 26 into grounded?
weedsnager said:Cheese said:Is the electrical outlet that you've plugged the CT 26 into grounded?
Yes
I tested it with an outlet tester, I’ll test it with multimeter laterCheese said:weedsnager said:Cheese said:Is the electrical outlet that you've plugged the CT 26 into grounded?
Yes
You've checked it with a meter?
weedsnager said:Getting shocked from my sander, using it with the Ct 26, both are brand new, anti static hose…
Any help ?
Cheese said:When I used the older TS 55 with a CT 22 in a detached garage, I got shocks all the time as my legs/hands came in contact with the vac hose. The outlet was the grounded style but upon opening it up, there was no ground wire attached internally.
That was one of the considerations that led me down the cordless path with the TSC 55 K. [smile]
Michael Kellough said:[member=44099]Cheese[/member] I don’t follow, how is a saw without any cord whatsoever a different static shock producer than a saw without a proper ground?
Michael Kellough said:Cheese said:When I used the older TS 55 with a CT 22 in a detached garage, I got shocks all the time as my legs/hands came in contact with the vac hose. The outlet was the grounded style but upon opening it up, there was no ground wire attached internally.
