Bugsysiegals
- Mar 19, 2016
Packard said:"Corner Weld" glue revolutionized the picture framing business back in the 1980s. It replaced white glue (Elmers) and was much stronger. It was said to be "optimized for end-grain (miter) glue-ups".
I tested its strength recently against Woodworkers III and found that they were essentially equal in strength (Woodworkers's I, II, or III were not available when CornerWeld came out).
What I did find is that CornerWeld glue would set-up in under a minute. I would apply the glue to the surfaces of the miters, rub the surfaces together and within 30 seconds they would no longer slip and the grip would start.
Woodworkers III took about 10 minutes to achieve that same result.
So if you are looking for a strong bond and very fast setup, then look for some CornerWeld glue. It is not as easy to find, but it is sold through most picture frame wholesale suppliers.
Amazon shows the product but when you get to the site it is listed as "currently unavailable".
Lots of listings, but I don't know any of these vendors, so no recommendation.
https://www.google.com/search?client=firefox-b-1-d&q=cornerweld+glue
Thanks for sharing this glue! It's funny but even with the TB II when I was gluing a drawer it wasn't very long, a few minutes, and I could hardly slide the pieces to align them ... maybe from the glue aging, not sure, but I just need to work faster!
