Hammer sanding attachment.
Lbob131
Does anyone have the sanding  attachment  for the  Hammer bandsaws?
And how would you rate it?
I would not give this a 100% recommendation. It is very expensive for what it achieves and it is time consuming to set up. You get a number of steel rods plus a couple (or three) of aluminium blocks into which the rods are inserted. There is also the platen (the piece of steel that goes behind and supports the belt). There are 2 of these, one for providing flat support (sanding flat) and one curved (basically just a rod) for sanding curved surfaces.
Before fitting you have to remove the upper bandsaw blade guides leaving just the vertical rod. You also need to remove or adjust out of the way, the lower guides. You then mount the sanding belt and attach the various blocks, rods and platen. You adjust everything so that when the belt is under tension, the platen it in the right place and properly aligned.
I only tried it out very briefly and it seemed to work ok but it obviously isn't suitable for sanding large surfaces very accurately because the belt is narrow. The belt is also so stiff that if you use the curved platen, you don't achieve the ability to sand tight radii - barely any different to the flat platen.
You could save time in the set up by leaving the various rods, blocks and platen assembled and just attaching the whole assembly as one piece.
You do also have the inconvenience of having to align your bandsaw supports again when you put these back.
If I was to turn back the clock I might consider buying an oscillating spindle sander such as the Jet Jbos-5 instead.
Cliff
Thanks Cliff, This is something I have considered, think it will be the bobbin sander now.
Mike
Thanks.
Have been  looking at  felders "Schleffix"  spindle  sanders. Part no  09.0.027.
Which afaik  can  accept  standard  roll sand paper.
Went with the  Jet Oscillating sander  in the end.
Happy  with it except  the dust extraction  leaves a lot to be desired.
So  I improved  it  using a few pieces of  waste  plastic  and rubber.
Here  you see  just open  space  with Jets  dust  shute  in the rear... The green rubber  I added  also.
When it changes  to 45  degrees  this side is closed  quite good. But the other side opens  so I made  another  green  rubber  shroud  that covers that opening.
Here  you see  the main plastic  easily removable  cover  fitted  whilst the table  is in 90 degrees....
So all the suction is now pulled down through    the slots in the cover plates.
