mino
This story has nothing to do with capability and everything to do with assumptions in external sourcing. The more external/different the supplier, the more likely such an issue.Packard said:...
But very simple things may be beyond their capability.
A case in point: We ordered 500,000 welded D-rings from a Chinese vendor. These were low-tech D-rings used to hold down trucking tarpaulins.
We got them in. They looked great. Our customer sewed them onto the tarps. And then the failures started. The welds were failing.
We tested the D-rings on our tensile tester and we were getting failures at 120 to 150 pounds of static load. The D-rings had full penetration resistance welds.
The identical D-ring produced in our factory typically bested 400 pounds before failure. Our setups had a 390 pound before failure as a minimum.
We could not figure it out. We sent the samples to a testing laboratory to find out what the type of steel was used. (High carbon steel is particularly hard to resistance weld.)
The print called for C1008 - C1010 low carbon steel. This is the “plain vanilla” of steel, and is generally the lowest cost steel available.
I got a phone call from the lab. They said it was of no identifiable grade of steel and the chemical composition varied. They said, “It looks like they just melted down some steel scrap and turned it into wire.
I did ask about the silicon content and that was substantially above acceptable. Silicon will significantly compromise welds.
My point is, “this-project-is-so-simple-we-don’t-need-western-manufacturing-advice” is what got them in trouble.
It is the most common issue with (starting) outsourcing. The original manufacturer has a lot of "properties" of stuff they make undocumented and production carries itself on "tribe knowledge", acquired some long, long time ago, maybe even a century, but never documented anywhere. Or even just basic "tribe knowledge" in an area which many call "common sense" without realising it is not really such.
Then there is a decision to order this externally (does not have to be overseas) and the procurement team does not specify the (presumed) requirement since it is not written down anywhere and in some cases the last person who would remember where the requirement came from may be in the grave even by then.
In this case, the source of the issue was not the supplier but your procurement team:
- the strength and material requirements were not adequately specified
- they were not checked /before use/
- random validation/test procedures on items passing between companies were not established
As a result, the supplier did the only (economically) correct thing: Asked for an under-specified item, thus they priced and made stuff that met the requirements specified - and only the requirements specified. Probably just that it should be steel and it should have some shape.
It is a mistake to infer a specific supplier capability from a mis-communication on a specific order. Judging a complete supply chain in this way is even more misguided.
Today, outside very-specific items where there is low production volumes and lots of empiric knowledge is required the Chinese manufacturing supply chain is something in front of which the whole German supply chain looks punny. Both on size and on breadth.
There are very few things one cannot get in China today - basically that is chip manufacturing tools in the 7 nm and smaller scale and related tooling and top end jet engines. Those are some of the very few things they do not have mastered. Yet. One may not be happy about that, but the reality is that in most fields the apprentice has surpassed the master by today. May still sell the stuff under his old master brand name, but it is the apprentice developing new versions and improving on them by now.
