wptski
- Mar 7, 2016
That's clearly a #10. The 18TPI and 19TPI are pretty close, did it go on real tight the first time?? ;D The push to connects I've used for the standard Fuji 6mm tubing only comes with British pipe threads. A British 1/8" is 28TPI where a USA is 27TPI, they work but one needs watch how deep you run a tap in.tjbnwi said:I'm pretty sure they're a number 10 (or my eyes are worse than I thought). Did not check the thread.
Yes, they are stainless steel.
I use the harder hose push lock connector to check valve, soft hose check valve to cup. With the way my gun is now set up I could get away with no check valve, it makes a nice connector and does no harm. If your gun is stock you have to use a check valve.
The stock Gxpx only needs the check valve to keep the material from getting into the gun's air only channels. You wouldn't need it for the PPS "unless" the material somehow got past the liner into the cup. I'm going to use a Fuji pressure with a check valve and adapt it to the PPS soft tubing because the Fuji tubing is too stiff to use on the PPS cup as I don't want to break it!
