brandon.nickel said:This one has been debated many times. The consensus is that the OF1400 is way overkill for a router table in terms of function and cost. It does not have an easy method of adjustment from above the table, nor does it really have the power to spin large panel raising bits (75mm+). For less money you can get a router and lift that are more powerful and work with the router lifts from Woodpeckers and JessEm. I personally have a Porter-Cable 7518 motor mounted in a Woodpecker's QuickLift. I think the OF1400 is too good of a hand-held router to limit it to under-table work. I'm also personally too lazy to mount and dismount it whenever I want to change operations, so for me two separate routers is a must. The PC7518 is the de-facto high-end standard, but many people are using Freud or Triton and are very happy with them.
rodwolfy said:Brandon,
You seem to be familiar with routers. I have a Bosch 1617vs with the plunge & fixed bases, a 1618Dvs, a Hitachi 3hp (in a table), a Bosch Colt, a Makita Laminate trimmer and a 3hp Felder shaper. The only thing that I don't like about the Bosch's is the lack of dust collection, especially on my Leigh D4R. Do you or the others really think that the Festool 1400 is worth the money over the other routers out there? What could I do with it that I cannot do now? I'm sure that I could figure out some way to run my current routers off the guide rail...
Rod
rodwolfy said:Lou,
Thanks for the post. I was wondering about getting one or something else. I wanted to get the package discount of buying two tools at once - saw/mft and then vacuum/??? Ideally, they would have some kind of a package deal for a discount on 3 tools, but no such luck! I've been thinking about the Domino, but at a cost of about $1k for the unit and tenons, it's quite steep. (I already have a mortising machine and biscuit joiner!) Anything else I should consider?
Dave Ronyak said:Rod,
A similar phenomenon tends to occur to my Fein vac, too. The wife seldom goes for the Festool vac - too heavy for her, and she is concerned that Festool's hard plastic wheels may scratch the wood floor. Although I have both vacs, the Fein gets more use overall. I have not had much of the issues with my Festool sanders when coupled to the Fein that others have expressed when full vacuum suction is applied.
I hope all goes well with repair of your rotator cuff, and that you're back in the Festool saddle soon.
Dave R.
I also seek to maximize versatility when choosing equipment for my home / hobbyist shop. For my limited use as a hobbyist working at home the volume of both the Fein and the C22 are adequate, but that will depend on what use you intend to make of it. If you are planning to connect your vacuum machine to a power planer, or make lots of dados or making raised panels with your router, you're going to fill either of those vacs fairly quickly. I addressed that problem by inserting a mini-cylcone (Oneida Dust Deputy in my case) between the tool and the vac. Most of the dust and chips end up in the drum below the cyclone and never reach the vacuum bag. You can find other discussions on this forum about the cost and efffectiveness of various options which range in cost from about $20 for one of those "cyclone lids" on a pail/drum to >$200 for a top cyclone with collector drum and hoses and fittings. If you plan on making lots of chips with your router, I recommend you consider getting a 36mm hose as well because it is less likely to clog due to larger chips and splinters being torn off when routing edges. You can buy a 36mm hose separately, or obtain it as a component of one of Festool's cleaning kits. I chose to buy a cleaning kit, and a hose-to-hose coupler, which enables me to string 2 hoses end to end (after applying a couple of wraps of vinyl electrical tape around the tool end collar on the 36mm hose) so I can reach anywhere in my shop without having to move the vacuum.
Dave R.
Bob Childress said:Just my 2 bob's worth.
