AlexThePalex
- Nov 12, 2008
Jiggy Joiner said:The computer control allows easy maintenance and servicing amongst other things.
It makes complex tasks easier. But it makes easy tasks more complex.
Alex said:threesixright said:Yeah my bad, obviously I should have said its a MCU. Which is a totally different ball game.
Properly some PIC or Atmel. And these are pretty robust. Nevertheless, not too differentiate, but to measure the temperature and suction level. Although you can do that also analog, I guess using a MCU is a bit easier. BT is just a gimmick, yet it comes in handy from time to time.
MCU? You're starting to lose me here. You mean Media Control Unit? Or the Marvel Cinematic Universe? Sorry, I had to google that. Whatever it is, if it requires software, it needs a CPU to function.
As for bluetooth, it is very convenient to have devices communicate with each other. I think lots of people like to activate their vacs with the bluetooth function. But then again, why on earth would you want to read the temperature and suction level on your phone? Now that's a useless gimmick. If those values are so critical (which they aren't) put an LCD display on your vac.
A basic rule for good design is to not make things overly complicated just because you can.
It's nearly 2020, you should replace these broken CPUs [wink]Alex said:Pentium processors in our computers
Depends. While the MCU itself is more complicated than the individual building blocks of a discreet analogue circuit it'll likely have a lower complexity than building a given functionality from discreet analogue components - while also avoiding the interesting problems that can turn designing analogue circuits into nightmares.Now what's inside the Midi Vac or a battery is indeed an MCU, and that MCU is a small computer that is a lot less complicated than the computer you find on your desktop, but it is still A LOT more complicated than all the other electronic parts that can make up a circuit.
That isn't the case for everything that isn't a trivial function, on both accounts (complexity and stability).Anything that runs software, like an MCU, requires a lot of complex components, which gives the designer a lot of flexibility, but it also sacrifices stability compared to hardwired components that only do a single function.
Only in case the update process wasn't designed to be resilient against being interrupted in the first place.Firmware updates are notorious for their possibility to fail and render the entire device useless.
Except they have a firmware upgrade process that is able to fail.threesixright said:Bottom line: IMHO there is nothing wrong with FT using a MCU + some BT in their tools
But thats just wacky implementation by FT (or 3rd party)...Gregor said:Except they have a firmware upgrade process that is able to fail.threesixright said:Bottom line: IMHO there is nothing wrong with FT using a MCU + some BT in their tools
