threesixright
- Aug 17, 2017
Hi All,
The house we bought has a few sliding doors. A few op them (inside and outside) are pretty damaged by scratches of cats (and a dog)
For some its on the door (can be removed) others have it on the window (fixed). See pictures below for some of the damage.
We want to change the color anyway (probably white-ish), so needs to be sanded.
What would be the best approach to repair these scratches? With the current color you can still see some of the grain. If you just put some filler on it, I'm afraid you will definitely 'remove' the grain.
Any idea what would be the best way to approach this 'restoration' ? The kit is also pretty yellow (guess from the sun), is that something I can replace myself?
Also open for a FT sander suggestion
Thanks!
[attachimg=1][attachimg=2][attachimg=3][attachimg=4]
Thanks!
