digilante said:Hi,
I have never had the opportunity to handle a Festool router. My old Bosch blue GOF-whatever is also around 20 pounds, but from the very start the "pillars" on which you lower and raise the router were not smooth going - it was really an uncomfortable, unpredictable, and uneven movement leading to mistakes and ruined wood - no smooth start too.
I can imagine, no matter what the weight, if the movement down is smooth and predictable and it has a soft start, then it should be quite a pleasure to use.
Well, so a few messages before this one I decided on the 2200 for the CMS-OF module... now I don't know anymore ;-) Thanks guys ;-) Seems the 1400 could do as good a job... I would still love a cordless 1010 though, for light hand work and for use with the templating system.
Thanks again,
Peter.
Peter Parfitt had good advice on the 1400 being capable in the CMS. If you are doing larger diameter panel bits the OF2200 might still be the better choice. That sucker has so much power it doesn't even break a sweat milling hardwood door stile and rails.
The 1400 will do it - I've used the Infinity panel door sets - but you can tell it's working hard and needs a slower feed rate.
Swapping in and out of the table just takes a minute or two. No bigger deal than changing out your bit and setting up your fence.
Where you might have frustration is if it's your only router and you're constantly swapping back and forth. That gets tedious.
Save your self some time overthinking things... just buy all three routers.
