Hints to drill holes without LR 32
woodferret said:
pixelated said:
The fence on the Kreg jig for the hole setback from the edge doesn't match the Sys AZ specification, so a little measuring is needed to position the jig. Once you've drilled a couple of holes, it's not a problem. Just make sure everything is straight as you go along.
My Sys AZ cabinet has quite a number of extra holes that were learning experiences. Happily, most of them aren't visible. [wink]
I like Mike35x95x1's solution the best, but if anyone is ever stuck with the Kreg jig, the far edge is at 66mm so reverse their included fence with a mod fence as per (below vid) and add a 8mm packer.  That'll bring the auxiliary fence to 58mm as spec'd - if you're not inclined to have to measure every time.  It's already a useful mod to get the 37mm on the closer edge.
I am one of the ones stuck with a kreg jig so that video is much appreciated.
