sancho57
- Jan 13, 2011
I use 2 1400 holy rails and connect them with no issues whats so ever. On the end stops that come with the LR 32 system when you look at the side that has the 16 stamped on it you will also see a equal sign = stamped on it. Place the equal sign in the center of the gap between the 2 rails and you got 32mm to continue routing holes in material.
Its easy, never needed anything more that the festool connectors and the LR 32 end stops to achieve great results
