Mismarked
- Oct 8, 2014
Here’s my take one the homemade boom arm with tool caddy. Not the prettiest thing, but sturdy and functional. Sits flat on the CT surrounding Systainer 5, and top shelf is low enough to allow Sys lid to open. If needed, lifts off easily and sits flat on floor. Basically a few scraps of ¾ cedar plywood, some dominos, a block of some kind of oak, an old aluminum rod salvaged from a broken clothes steamer that my girlfriend was throwing away, and 2 Zip ties. Oh, I did spend $1.34 on the PVC.
The tool caddy is still trying to decide what it wants to be when it grows up. I didn’t start the project with a design, but instead started with two same-size scraps from a shelving project that were sitting on top of the Systainer. The new Carvex looked a little hungry, so I decided to cut a hole in each piece approximately the same size as the Sys footprint, and then just started putting it together in a configuration that looked right.
I might add a toe rail on the front shelves to keep the TS-55 from sliding off. A swing-out piece on hinges to hold the larger CT hose would help free up the Systainer for something else. I will probably install a grid of Domino holes on the front vertical piece to hold a couple of combination squares, etc. For that, I am going to use 8 or 10 mm Sipo (to match the cedar), install them with the Domino holes in a vertical configuration, and put a notch/kerf in the Dominos to hold the blade and keep them from sliding off when I roll the cart around.
