Tom the Remodeler
- Dec 30, 2007
Hi again everybody! So I'm about to take the plunge into a C12, and in my research I noticed some huge discrepancies between the different drill/drivers on the market in regard to their rated torque. For years it seemed like torque was rated in inch-lbs, and most professional 18volt drills seemed to hover around 500 in-lbs. Now, my understanding is those measurements can be pretty misleading because there was no industry standard method (in NA) for measuring torque. However, I remember a blurb in a trade magazine a few months ago about a new industry standard agreed to by all of the major tool makers so it'd be easier to compare models. So, now I'm looking at my 2008 Hilti catalog, and it states that they are using a European standard that provides two torque measurements: "hard joint" and "soft joint". Apparently "soft joint" torque is most applicable to construction, and nearly all of the Hilti drills, from 14.4v to 15.6v to 18v all rate at 292in-lbs, with the 24v rated at 398 in-lbs and the 12v at 186 in-lbs (all in wood). This makes a little more sense to me that the C12 would be rated at 265 in-lbs in steel and 160 in-lbs in wood. However, now I go to the Dewalt website and see they are now measuring in "Unit Watts Out"? What gives? Does anybody know what the future, standardized unit of measure for torque is going to be? Thanks!!
