Assume I don't know anything; which is kinda true, I am about to use my Domino for the first time on a real live project.
I am making a frame out of 2.5" wide 1.25" thick stock with miter joints; the frame will be 1.25" deep when complete. What exactly do I do to get the dominoes in? I know how to do an edge joint, but this is is rather more complicated. With a biscuit jointer I would just mark both pieces and go to it, but my understanding is that doesn't work well with the domino; and the biscuits have ample side to side slop built in.
Before owning the domino I would have stacked two biscuits, but there probably isn't room to do that assuming I want to use a 10x50. There is room to put a 10x50 on the inside of the joint and a 5x30 on the outside, but if my alignment isn't perfect it won't go together then. And maybe that is overkill?
Any advice would be appreciated.
