- Jun 24, 2007
This thread may be redundant or similar to another but I could not recall or figure a good way to search for it. So here it is anyway
I am interested in a discussion of how everyone does there job, work, or hobby. What I mean by that is, your shop and or site methods. Do you use Systainers, Sortainers, or some other container? Do you keep the tools plugged in and ready to go at the bench? Do you have separate work stations or one main work area? Do you set up shop on site or primarily work out of the truck? The nature of what you do will play into this so please include that also if you like.
I primarily build custom pieces out of wood. I also do some repair work on furniture, but straight refinishing jobs are out. I would say my specialty is specialties. I mainly work in the shop, and generally site work is limited to installs or modifications of something that is existing. But if the piece is easily moveable it goes back to the shop.
My traveling kit ( as I call it) consists of what would fit into about three or four Systainer IV s. It is currently in other types of tool boxes, but I am working out the best combo of Systainer and Sortainer to switch too. I am continuing to use it the way it is for a little while in order to optimise the tools and such before I decide which Tanos items will work the best. It is compact enough to fit in the back seat of a car when desired. If i need a particular tool that is not in the kit (a Sawzall for example) I add it in for the job.
In the shop I have one large main work bench and a separate cutting table ( http://festoolownersgroup.com/index.php?topic=3318.0 ) . The tools are almost entirely stored in cabinets. When I first started buying Festool I was impressed by the Systainers, but did not use them. It seemed to be a nuisance to take tools out of cases. To me the Systainers looked more useful for site work and transport. This was partly due to the fact that I had only the ATF55 and guide rail accessory set. All of my other tools were in cabinets easily accessible on shelves. So the ATF went on a shelf like the rest. That was my tool system if you will and seemed to work well.
As I started acquiring more Festool products I began experimenting with using the Systainers in the shop. What I have now discovered is that even though I have to open, close, get the tool and such out. It actually saves me time and effort. Why? Because I no longer make multiple trips to the cabinets for tools , accessories, bits, etc. When I need the router I take the bit off a hook (soon to be in a Systainer, and grab the router case. Everything that I currently have for the router is in the Systainer (and it all fits with out a jumble). Walk to the bench were it will be used and thats it. I used to get frustrated having to keep going to the cabinet everytime I changed my mind on the set up etc. And often made at least one extra trip to get something I forgot, like a knob for the edge guide or some such item.
Now if I use the LS130 I pick up the LS130 Systainer attached to the abrasive / pad Systainer and I have it all. Same for the ETS150 I used to invariably go back to get a different pad or another grit. Now it is one door opening, one grab, one trip to the bench.
I can definitely see why this method would not work for everyone. Differing shop layouts, multiple work stations, a more production type set up rather than one of a kind items, as well as personal preference. All would play into this. For example I have seen people work more efficiently with less organisation (at least I would call it less) because it took them too long to organise. Different minds work diffrent ways.
So what say you all? Please post how you work. I welcome comments on my method as well , good or bad.
srs
THREE
srs
THREE
