How much sawdust is expected with a TS75?
[member=64213]schneems[/member]  pull the side plate on the saw that covers the blade. There are 5 T15 torx screws holding it on. Don’t lose the hose connection when it falls out.  [wink] obviously with the saw unplugged.
Ripping cuts can make some string like threads instead of dust and chips sometimes they can clog up in front of the outlet. This was mine just a few minutes ago.
I also use the 27 mm hose with mine. It’s fine unless I forget to turn it up to full blast.  [eek]
Ron
[attachimg=2]
Yikes! Thanks for the tip. Could you see something was in there before you removed the cover?
