Thank you. Sorry I felt the need to mention this here, but, oh well, too late to do anything about that now. But again, thank you.
As to the Incremental Track for parallel cuts, I simply use two separate lengths of track as story sticks such that I can locate the guide rail at the desired location. The scales and stops on these lengths of track have been calibrated alike, and also to account for the width of the guide rail. In use, the end of the track butts against the guide rail with the stop at the other end to locate the edge of the material to be cut. The lengths of track can be clamped in position if needed, or simply removed once the guide rail is in place.
A similar arrangement is possible for cuts on the other side of the guide rail, with the end of the track (gently) indexed off the splinter strip. Here, the scales and stops are calibrated to allow for the saw's kerf. To clean up the ends of the splinter strip, connect with another guide rail and cut, repeat at other end. Now entire length of strip is in line.
There are other ways to utilize this versatile track. I like it for the accuracy, repeatability and step-and-repeat capabilities it provides. I also have the LS Positioner, which I also like. Incra offers an inexpensive (if $60 is inexpensive, that is) version that is a copy of their original product from, oh, maybe the late '70s or early 80's. Don't for a second that this little guy is only usefull on a router table. Try it on your drill press. I could go on, but you get the idea.
I hope that this has conveyed enough for you to see the various possibilities. If not, I would be more than happy to elaborate further on this thread.
Happy woodworking,
Corwin
